The LarePass VPN provides secure remote access to your Olares device, even when you’re on a different network or at a remote location. Olares’ Settings app offers advanced configurations to tailor VPN access to your specific needs. Here, you can enforce VPN connections, enable SSH access over VPN, or route traffic through custom ports.
Allow SSH connections via VPN
This enables SSH access to your Olares device through the LarePass VPN, even when you are in a different network or working remotely.
- Open the Settings app, and select System > VPN.
- Toggle on Allow SSH Access via VPN. Port 22 (SSH) is automatically added to the configuration.
Allow subnet routing
This feature allows you to access other devices in the same local network as your Olares through the VPN.
- Toggle on Enable subnet routes.
Enforce access using VPN
To ensure that all traffic to your private Olares applications is encrypted and routed securely, you can enforce VPN access. This ensures that connections to your Olares always go through the LarePass VPN, regardless of the network or device used. Enabling this mode will block accesses to Olares via reverse proxy.
To enable the enforced VPN mode:
- Enable VPN connections on at least two devices using LarePass (typically a computer and a mobile phone) with LarePass installed. For detailed instructions, see Enable VPN on LarePass.
- In Olares, navigate to Settings > VPN.
- Toggle on Enforce VPN access to private entrance.
When successful, you’ll see a confirmation message at the bottom of the screen.
Configure ACL rules for port access
After enabling subnet routing, you can further configure ACL (Access Control List) rules to allow traffic to specific ports based on the services you want to access.
For example, to access a Windows server via Remote Desktop:
- Click add to open the Add ACL dialog.
- Enter
3389(default port for Remote Desktop Protocol), and click Confirm. - Click Apply to apply changes.
Now you can use Windows Remote Desktop to access the Windows server in the same LAN as Olares.
