Update on the OWC Thunderbolt 10G issue
I was able to narrow this down further.
Known good before the upgrade:
Olares 1.12.4
BIOS 1.01
OWC Thunderbolt 3 10G Ethernet Adapter
Used as my normal day-to-day NIC without issue
After upgrading to Olares 1.12.5 and updating BIOS from 1.01 to 1.04, the OWC Thunderbolt 10G NIC stopped working.
With BIOS 1.04:
BIOS optimized defaults appear to disable TCSS / Thunderbolt.
After re-enabling TCSS / Thunderbolt, the OWC adapter appears under Thunderbolt sysfs but remains unauthorized.
domain0/iommu_dma_protection is 0.
Manual authorization fails with Input/output error.
dmesg shows PCIe tunnel activation failure.
The Aquantia AQC107S endpoint never appears in lspci.
I then downgraded BIOS back to 1.01.
With BIOS 1.01 and Olares 1.12.5:
The OWC Thunderbolt adapter authorizes successfully.
domain0/iommu_dma_protection is 1.
The Aquantia AQC107S appears in lspci.
The atlantic driver binds to enp10s0.
I initially saw instability after that, including PCIe/AER errors such as MalfTLP, CmpltTO, BadDLLP, and atlantic reporting that it could not recover.
I then disconnected the onboard 2.5G Ethernet and booted with only the OWC Thunderbolt 10G NIC connected.
In that state, the system is currently usable:
enp10s0 is UP
IP address: xxxx/24
Default route: via yyyy dev enp10s0
Link speed: 10000Mb/s full duplex
Link detected: yes
However, dmesg is still repeatedly logging correctable PCIe AER errors on the Thunderbolt PCIe path:
pcieport 0000:09:01.0: PCIe Bus Error: severity=Correctable, type=Data Link Layer
BadDLLP
So BIOS 1.01 restores functionality, but the Thunderbolt PCIe path still does not look clean under Olares 1.12.5.
Current conclusion:
BIOS 1.04 appears to introduce a Thunderbolt / TCSS / PCIe tunneling regression on this hardware.
BIOS 1.01 restores the OWC Thunderbolt 10G NIC, but with Olares 1.12.5 I am still seeing repeated correctable PCIe AER BadDLLP errors on the Thunderbolt PCIe path.
There may also be an issue with the post-upgrade dual-NIC/network state, since the OWC NIC is usable when it is the only connected Ethernet interface.
For now I am staying on BIOS 1.01 and using only the OWC Thunderbolt 10G NIC. Please investigate the BIOS 1.04 Thunderbolt behavior and confirm whether 1.04 has a known issue with Thunderbolt PCIe tunneling, TCSS defaults, or OWC/Aquantia AQC107-based Thunderbolt adapters. Please also advise whether the repeated BadDLLP errors under BIOS 1.01 + Olares 1.12.5 are expected, known, or something that requires a kernel/firmware fix.
