Model Consoles: rollback or optional updates
Hi, deepreinforce removed for some reason Q4_K_M from HF :sweat_smile: Delete ornith-1.0-35b-Q4_K_M.gguf · deepreinforce-ai/Ornith-1.0-35B-GGUF at 8b8ed7d
Which breaks Ornith 1.0 35B from market. Do you plan to implement some rollback feature? or some optional updates like I would expect to be prompted that new version is available once it would and I could update model or not.
Hi - thanks for reaching out. We saw that the upstream repo deleted the Q4_K_M file, which is a pretty unexpected and rare situation. Because of this, we had to temporarily remove the Q4 version from Olares Market.
Regarding your suggestions to protect users from unexpected upstream changes like this, I’ve logged this as a feature request and shared your feedback directly with the dev team for evaluation.
Just a quick follow-up on this:
If you have already downloaded Ornith-1.0-35B (llama.cpp), your current setup won’t be affected and you can continue using it as usual. Should the upstream author restore the file in the future, we will update the Market accordingly.
In the meantime, as an alternative, you can also try using the Ollama version of this model.
